Lets say you had two identical engines built. You had found two cams with the same lift and duration at .050 but one had .100 more lift than the other. How much power would you lose by running the cam with lower lift? Just for reference one had .520 and the other .620. 454 with 8lbs Boost 8.5 comp. Pro comp alum heads.
