I am doing a budget build on a little small block Glastron CSS 19 with an Alpha 1 drive. I have a virtually new 260hp GM Target Master 350 laying around that I am putting in it. I also have a fresh set of old school 202 camel hump heads I am planning on putting on just to get a little more hp out of it. (I know there are better heads out there but I have these already and they will be better than what is on there now.) According to my research the 64cc chambers should bump the compression up to approx. 9.1:1. I will be running the stock Mercruiser wet manifolds with through prop exhaust. (At least for now.) I am looking for a cam that will work good but not have a reversion issue. I am looking at the cam in the link and talked to a tech from Comp Cams but he didn't have any definite answers and kept referring to it as a revision issue. Question is will this cam work alright or does someone have a recommendation for a better one? I just want to get the most (dependable) hp out of what I already have. Thanks in advance.
12-236-3 - Xtreme Marineâ„¢ Hydraulic Flat Tappet Camshafts
