1 - 20 of 23 Posts
Do you guys have to jack up the motor to change the oil filter?
Can i buy one that's a little shorter?(I think 1/2 in shorter would work)
Do i need to run a marine oil filter or is auto fine?
Boat Nut
If thats a Ford, you can find the angled filter adapter, was used on the trucks, and retains the stock filter, but at a diferent angle.
I'm baaaaack...
No need to change it, just poke a hole in it with a screwdriver to get the old oil out:D
Yeah, it is a Ford... they just figure that you'll blow it up before it ever needs to be changed and a new one can be slapped on at that time. :D
add a remote system. auto filter would do just fine.
($50.00 bucks at summit)
a good car filter is fine - wix, k&n...
how long is that thing, and why are you running an evinude oil filter???
Haha. I thinks thats actually described in the owners manual.
Why not just cut the stringer? Im sure a sawzal will take care this issue. :)bulb
Im sure it will be ok, you have two of them.
Glendale Arizona
This is what I use. I had the remote with stainless lines and anodized fittings and got rid of all that crap for one of these. I much prefer this setup. Nice n neat, compact, still able to run a full size filter, clears the stringer and engine rail and works great. Nomenclature isn't 100% correct though. It says rotates it to the front. I've got mine going to the back. You can position it any which way.
Great piece and as I recall pretty resonably priced. I think it ended up being less than the remote, the line and fittings to reach it.
Yeah it's dirty.............so what.
hey dan, does running a shorter filter like i do, have any bearing on the oil flow???
cj812
k&n hp2004 is the short filter and works fine.
if you go to a re-location kit DO NOT use the cast one. i had one blow off the block (bad threads) could have been really bad.
What the Hell is That?
Seems to me it would be a PITA to change the filter as soon as you unscrew it oil is going to drip everywhere.
1 - 20 of 23 Posts
