1 - 18 of 18 Posts
Really? Yes this is a family boat more or less, I just want to know what the good SBC pans are, in case something used turns up. Thank you
Canton has a nice pan good welds ,Plus check there clearance section you can get lucky and get one at half price that someone ordered wrong and sent back
quite a few pans on canton web site in the garage sale area https://www.cantonracingproducts.com/store/blem_list.html
11-076T​
SBC CT PRO POWER PAN 1 PC SEAL​
DISCONTINUED​
$312.80​
11-120​
SBC 12" LONG SUMP CT PAN​
Old style pan must use short filter​
$199.75​
11-120T​
SBC 12" L. CT PAN 1 PC SEAL​
Dipstick rewelded not replated​
$216.24​
11-190​
SBC OPEN CHASSIS CT PAN, 6.5" DEEP​
Sump Crooked​
$218.96​
13-600​
302 STOCK ELIMINATOR OIL PAN​
POWDERCOATED​
$153.00​
15-286A​
LS NEXT FRONT SUMP ALUMINUM RR OIL PAN​
Scratched​
$550.80​
15-580​
HOLDEN V-8 FRONT SUMP STREET STRIP OIL PAN​
Ugly Welds​
$235.28​
16-080T​
S. B. CHEVY '86+ 10" DEEP SUMP TRUCK PAN​
Blemished​
$293.08​
16-100​
SBC S10 CONVERSION PAN​
Fixed weld and lumpy powder​
$173.40​
16-100T​
SBC S10 CONVER. PAN 1PC SEAL​
Dented Corner​
$173.40​
16-330​
BBC MK IV DEEP SUMP TRUCK PAN​
Dented​
$208.08​
16-330T​
BBC Deep Sump Pan​
Used, Powdercoating beat up​
$208.08​
18-302​
BBC F.L. Sump Marine Pan 1PC Seal​
Seal out of Round, Still Seals​
$208.08​
None of them. You will have windage and pressure problems with all of them. Get a good custom kick out pan from Williams or Dan Olsen. That box style pan idea for a jet boat is garbage. If you spin less than 5000 rpm you’ll be ok. Anything more than 4.00 stroke you’ll find out the hard way.
Discussion Starter #10 (Edited)
I do not plan to exceed 5000 RPM. Is a $400 pan overkill? (SBC 400 is 3.75 stroke)
Thank you
I'm sorry I must have been sleeping when I answered you the first time. No it will be an open system.
Thought I'd warn you that a SBC 400 has steam holes in the head that will quickly get plugged on a raw water system. I have a heat exchanger and run antifreeze in my block.
Sent from my Nexus 9 using Tapatalk
Discussion Starter #18
I am setting up my cooling very similar to how the Packajet was with circulation. Thank you for looking out for me I need all the help I can get.
1 - 18 of 18 Posts
