Can someone tell me what is the biggest size gear I can put in a 12 degree casale---without maching the water jacket out? Will a 42 tooth fit---is it better to use a 30 top gear and a 21 bottom to get1.43?
Bentshat 40% is the largest you can install and keep your water jacket.
The upper gear is small enough you should not have to remvoe
any of the case material.
Im confused the casale list says that 40% is a 42 tooth and a 30 tooth bottom--why cant I use a 28 bottom and get 50% Is there two diameters of 42 tooth gears?
Rex thanks for making it clear ---The water jacket seems pretty thick any chance of taking a few thou off to get the next ratio or two? thanks Hutch---
Bentshaft, our billet cases will take up to 1.57 with a water jacket. (Raised) I have one set left at $1000.00 for a pair, The Normal price is $1400 per pair. These are Casale billet cases, from RBR.
A forum community dedicated to performance boat owners and enthusiasts. Come join the discussion about offshore racing, performance, modifications, builds, classifieds, troubleshooting, maintenance, and more!
