What is the proper amount of tension on the spring that presses the ball bearing against the shift crank in the in and out housing? I need to tighten mine up, as the handle doesn't want to stay where I put it, but i'm not sure if it's ok to just tighten it, or if the spring should be replaced. Could I pull out the spring and give it a stretch?
