1 - 2 of 2 Posts
$475. CASALE IN-OUT V DRIVE BOX GOES IN AND OUT OF GEAR EASILY. NEEDS SHIFT handle. HEAVY DUTY 1 1/8” output shaft. Water cooled. 12% gears? No whirl-away. Has cable drive tach hookup. HAVE LOTS OF OTHER FLAT BOTTOM PARTS ALSO. CAVITATION PLATE and HARDWARE, PROP SHAFT, FUEL FILLER CAPS, STEERING PARTS, DOWN PLATE HANDLE AND MOUNT. Prop shaft coupling. HALLET V DRIVE BARE HULL $100 no trailer.
Carlson Challenger...tunnel hull v-drive w/ BBF 460
do you still have the v-drive, and do you know if this could swap out a old top loader easily?
1 - 2 of 2 Posts
