1 - 13 of 13 Posts
SILVER COATED PLATE
ALL HARDWARE PICTURED WILL NOT SEPERATE PARTS PICTURED WILL SHIP ALL THIS
I HAVE THE ROD THAT GOES FROM THE TRANSOM TO THE T-HANDLE OR DOWN PEDAL (LOCAL PICK UP) HAVE 2
HAVE A SOLID PROP SHAFT YOU CAN USE FOR THE CAV BAR OR I HAVE 1 OR 2 BARS
LETS MAKE IT $275 THIS WEEK :duh:
thanks..if its local pick up somebody could be set up nicely have extra parts
Do you have any of the pins for the turnbuckles to the plate mount? I'm short 2.
“Some people spend an entire lifetime wondering if they made a difference in the world. The US military doesn’t have that problem.”
these if so swing by no charge
ok i sold the box of parts..have the back plate and long rods for sale..........................
cav parts
Hey Mouz, how wide is the back plate and how long is that 1" prop shaft? I might need the prop shaft to build a cav bar for my GN and the back plate would work if it's wide enough for it. Thanks In Advance
Discussion Starter #12
back plate 60"
prop shaft 63"
Prop shaft and Back Plate
Sorry I took so long to reply back but the prop shaft is a few inches too short as is the back plate. Thanks for taking the time to measure.
1 - 13 of 13 Posts
