Show u, did you replace impeller for impeller ?
Show u, did you replace impeller for impeller ?hey guys, got a question for you all, s.d 309 ,aa impellor, 351 w, suked a rok in last week, oops, impeller n.f.g... got brand new one on , comes out of the hole awsome,, then just about to plane out and she spinns her wheel hard! wear ring looks great, pump ony has 20 hrs on it, grate clean bowl clean, any other things i should be lookin for? thanxs.
nearly anything (string weeds or "a little piece of rubber") could do it Tomi ordered the same size and model,"aa" was on the old and the new one has "aa" stamped on it also, they both look the same, i didnt use a feeler gauge to check the gap from wear ring to impeller, but it seems to fit alright? took the bowl off last nite and found a little piece of rubber on one of the blades??? would this be my issue????
