A while back I thought I read a post from someone about some vibration problems they had with a Champion V drive. I can no longer find that thread. Any help would be appreciated. Long story short... I need stories of vibration problems asociated with "Non Braced" Champion V Drives and struts with missing front bushings and the massive damage it causes to hopefully win a small claims case against a customer that truely beleives that there is "no way" that the vibration from the propshaft, v drive and driveshaft, could cause the trans case to loosen enough to come away from the block and damage the trans. This thing shook so hard it broke the starter, loosened motor mount bolts and the headers, bent the propshaft, the output shaft of the v drive , the output shaft and flange on the trans. I go to court on Monday, so rapid replies are appreciated.
