i have a very light aluminum flywheel i havent weighed it 8-10 lbs probly it is for internally ballanced chevy engine's only it has the olds style 2 piece main seal style flange it will work with any small block excluding stock crank 400's and 383's however if you have an internally ballanced aftermarket crank in your 400 or 383 it will work... also it will work with internally ballacned big blocks im am pretty sure that the 454 was the only externally ballanced bbc but am not for certin it will deffinatly work with ALL internally ballacned strokers i will get pictures up as soon as i get it back from the machine shop from getting it surfaced the hardened surface on the flywheel is gone you could not put a clutch on it but would make an excellent boat flywheel 150 shipped anywhere in the us call 618-920-2827
Hydroguy was all over the internet looking for one.
Discussion Starter · #4 ·
thanks guys just checked that out looks like he found one two days ago ...if i had only started looking around my shop a few days earlyer :)st still for sale!
I'll take it.
Steve Peterson 714 579-7857 hm 714 883-1715 cell
