Dropped Weiand Stealth intake and Berk droop at polishers. Ordered pick up from Rex for the Dooley pan and also a nozzle gasket. Ordered loader from Chris at B1 (very excited about this part). Once I get all the parts, I'll pull the motor to fix some leaks and install intake, pan, and loader. Will take measurements and angles so B1 can build a shoe at that time. Then I need to save up for new gauges, fuel sending units, and flush fuel fills. I've been told the fuel fills are notorious for letting in water so I'll have a water separator to the fuel system. Not sure if I should put it before or after filter.
