Classic/Vintage 1964 Home Built 16' V-Drive Flat Bottom Boat
All Original, Runs Great!
Perfect for Classic Resto/Refinish Project, or can be used as is with TLC.
Great high quality built Traditional Mahogany Deck and Marine Plywood Hull W/Glass Overlay Construction. Hi Quality Design & Fab of Metal Components.
I do not know name of Hull Design Plan, but is similar to many early 60's Vintage Flat Bottom Designs out of California on the web.
Motor: 1968/69 Pontiac 400 cu.in., Block Date Code H308, M/T Valve Covers on 62 Casting Heads.
Super Rare Nicson Carb Spark Arrestor Mounted on Holly Carb.
Trans: Turbo 400 Automatic Trans attached to Halibrand V-Drive.
Edelbrock M3 Marine Wet Exhaust.
Rare Hall Craft Deck Mount Speedo Housing.
Jabsco ext. water pump with new impeller installed.
Sturdy Hand Built Trailer with Aluminum Diamond Plate Side Steps for Easy Boat Entry and Launch.
Boat/prop currently set up for Water Skiing, does have a speed limiter (currently unhooked)
Original Interior is in need of Repair or Replacement, but is usable as is.
Mechanically, just needs new Carb Accelerator Pump, and 1 of 2 Gas Tanks Repaired.
Classic Motor and Trans alone worth asking price,
$6000. No Trades.
Boat has Title, current Licenses and Registration.
