G
Guest
·Say you've noticed what appears to be spider webbing of your clear coat. Very very fine cracking, not like its coming off in chunks or anything. Definitely not scratches, but you can kind of feel it with your fingernail. Its not even easy to see to the untrained eye (I've trained my eyes well
The cracking kind of follows the waterline angle when the boat is on the launch ramp and is almost limited to that same area. i.e. no cracking on the deck, bow, hatch, hull sides, etc. Those areas are pristine. Only on the rear quarter sides and transom where the water meets the boat on the ramp. Imagine the water splashing the hull on the ramp. No cracking above or below that area for the most part.
Assuming there were no errors made in the application of the clear, is it possible that the temperature shock could cause this cracking?? i.e. 115+d air temps (and possibly hotter gel/clear temp) and what, 68-72d water temps (Parker water is always cool
devil).
Assuming it was temperature shock that caused the cracks, is there a clear that is impervious to this situation? Or will all clear crack under these circumstances?
If it was an application error, please ignore this post.
And for the record, this is hypothetical
sphss
