Can you get at it? If you can wrap it in heat trace and hook it to a GFI then let it thaw.Our water pipe froze at the well last night. Anyone got any ideas on how to thaw it out before I put the insulation on it??
That's what I'm talking about!I used to soak a rag in gear oil, wrap it around the offending pipe, pour isopropyl alcohol over it, and set that mess on fire. The alcohol will ignite the gear oil, which will slow burn using the rag as a wick. Not for indoor use![]()
