With a wet sump AND a mag? Don't even consider it! The only time I would use one is with a dry sump and a dizzy. But then, with a dry sump and a dizzy, you could probably use an iron gear, and a bronze would last about ten years.Whats your take on the composite dizzy gear over a bronze?
Sure would be nice if they would do as advertised and stop the wear of the gear & contamination from the bronze.
