1 - 18 of 18 Posts
I have been trying to trace down low performance on my 2001 454 MPI MAG. I did a compression check today and they checked between a high of 120 PSI to a low of 80 PSI per cyllinder. I'm sure that I probably need at least a valve job. I'm planning to do a leakdown test on the low cyllinders tomorrow. What compression numbers have any of you seen on a bacically stock 454 Mag? Do any of you have any good head and cam reccomendations for a 454 MPI motor? It seems it may be time for some more power.
Thanks,
New here
Tyler Crockett Marine has a "recipe" for 454/502 marine engines. It's a "top end" kit, with their-spec cam and a bunch of parts that you have your machine shop (of choice) put in. Or, you can send your heads to them.
A guy here did this to his 502mag and was MORE than happy with the results. Easy 100hp just by "freshening" the top end of the motor.
http://www.crockettmarineengines.com/products.html
Here is the latest. Tried to do a leakdown test and none of the cylinders would hold more than 10/15 lbs with 50 to 90 PSI on the input side. I could hear most of the air excaping from the intake / intake valves. This seems to me that I'm doing something wrong as I would not think the boat would run with this much leakage. It actually runs pretty good at WOT, but it idles roughly. I tried a standard compression tester and they actually tested 10 lbs higher than yesterday. They tested between 90 and 130 today. The engine was cold today. Any thoughts??
80/90 psi is enough reason to tear it down. IMHO no reason to do a leakdown test at that point unless wanting to hear if air is going thru to crankcase or going past a valve.
Oh, make sure you are doing leakdown at compression TDC, not overlap TDC.
I rotated it all the way through to see if I was not a TDC. There was no position that raised the numbers. The weird thing is that I can get 5000 RPM at WOT and run 68 on GPS in a 25' Nordic Rage. I just have rough idling and a very poor holeshot.
Thanks,
Well the engine is coming apart. I'm going to go with the Tyler Crockett MPI upgrade kit.
It's what we do
Compression tests are a waste of time in my opinion. All it does is tell you to perform a leakdown test to find out what is really wrong. If the rings are fine and its the intake or exhaust valve you wont know that with a compression test.
I'd be asking if the valves are adjusted correctly.
The motor only has 210 hours. I am under the impresion that the stock valves and rockers are non adjustable.
New here
You DID do the compression test with the throttle WIDE OPEN, right??
The throttle was wide open. There is a problem in the valvetrain or heads. I just ordered Tylers kit. This should take care of what ever I find as well as pumping up the engine some. I'll report back what I find when it comes apart next week. Thanks for the suggestions.
New here
Good. Just wanted to make sure you had done the test right. Good job.
If done properly, you will be REAL happy with the Crockett kit. "Kevnmcd" on here did it to his 502. He was in the same sit as you and - from what I remember - was just going to freshen the motor up. I did the same thing and sent him the link for the engine kit. He got the kit, had all of the machine work done locally, put the motor back in and was real happy with it. The boat was (still is?) for sale now, as this was a couple of years ago. The cost of doing the kit as opposed to a stock rebuild would have to be fairly minimal and you get around 100hp boost.
Keep us all posted, as there are several others who are - or will be - in the same situation as yourself.
Here is an update. I have installed the Tyler Crockett upgrade kit on the engine. Still waiting for a few parts to finish. Hopefully in another week or so it will see water. The original problem of low leakdown pressures, 10 to 15 psi has been cured. After the valve upgrades and valve job the cylinders all held around 87 psi with 90 psi input this afternoon. That was cold. Can't wait to see how it runs with proper compression and the upgrades. I'll do a seperate report on how it runs with the Tyler Crockett kit when it gets into the water.
Say Mach80. Just so you know. A cylinder with 80-90 pounds is like dragging a dead horse. They do not even work. That is the reason for the rough idle and no hole shot.
Lovin' IT!
You never learn...:)
Discussion Starter #18
I thought I would follow up after the engine was back in the boat and running. I did the Tyler Crockett kit and I'll report on that in a new thread as soon as it has seen the water. Hopefully this weekend as the weather is looking good. The engine has been run on the hose and I did a Compression and leakdown check while warm so I would have a baseline for future problems.
The leakdown test was great with all cylinders holding around 87 PSI with 90 PSI input.
The regular cranking compression test had all cylinders between 153 and 160 PSI.
This is a huge improvement from the original test that showed all between 80 and 120 PSI.
Can't wait to get it wet.
1 - 18 of 18 Posts
