1 - 7 of 7 Posts
Half a bubble off
Curious what the masses have used to connect their dash mounted boost gauge to the motor? -4 SS seems overkill, plastic seems underkill.
Your thoughts would be much appreciated.....john
Have used both with good results. ss4 just much cleaner.
Some guy
You can use black hose, or I have seen some guys use stainless from the engine, and couple it to black hose under the gunnel where it doesn't show. You can also probably use -3 instead of -4.
i use -3 stainless all the way to the gauge, for oil and boost.
I used a roll of small dia copper tubing. Looks good enough for $15
1 - 7 of 7 Posts
