Members only
Thats right! Just switched over my Corvair to e-85. Got the carburator back form Performance Carb in Ontario and Ron did a bitchen job. Bolted it on and ran like a champ. The tunnel ram iced up & the carb was sweating like a pig. Took temp of manifold after running it for 20 min. Temperature on the outside was 50 degrees after sitting a few minutes while I looked for the temp gun. :partyguy: This thing is wedged in a blow up raft that I will be campaining in some white water events next year!:wink2:
If anybody needs a good carb guy who knows this stuff call Ron
Performance Carb
1408 S Grove ave Unit B Ontario CA
909-673-1180
And no Getrdone I don't build my own Carburators. I have to pay somebody for those too...:duh:
Performance Carb
909-673-1180
Well, it's good to see you are stimulating the economy..That's not a supprise....
I think Air cooled (mostly desert) stuff would see the greatest benefit from the E85. Tell me more about this corvair project. Or give me a link if you have already posted on it.
Oh yeah, change that damn avatar! It costs me about ten minutes of laughing 'till I cry every time I see it!!
My clothes always had dog hair inside them and I couldn't figure out why, until I came home early one day and caught him!
Members only
My avatar is a picture of my only son! Picture 078.jpg With out him its me and 5 girls! :)Unsure
The corvair is in an old hijumper I restored about 4 months ago. I have had it for 15yrs. Broke a u-joint in 04 at Glamis and after draggin out of the dunes destroyed the tranaxle. Parked it and started collecting parts. Now its mated to a bus trans with a Kennedy adaptor. 16" of travel in the ass & 10" on a beam front end. I added about 120' of tubing to the chassis. All new sheet metal from a friend of mine. Its a pretty cool old car. Looks like a 70's open class buggy. The corvair motor is pretty bitchen. The heads were milled off and had elbows welded to them. Somebody had made a custom 6 tube spider looking tunnel ram with an oil bath plenum and a 2bbl holley. I changed the plenum around and made it a 4bbl with a 650hp. Fair amount of head work, good compression, flat tappet cam from Howards cams. Over all a clean little set up. Makes good torq and will get with the program for an old timer... Picture 117.jpg
Platinum Member
My avatar is a picture of my only son! View attachment 128159 With out him its me and 5 girls! :)Unsure
The corvair is in an old hijumper I restored about 4 months ago. I have had it for 15yrs. Broke a u-joint in 04 at Glamis and after draggin out of the dunes destroyed the tranaxle. Parked it and started collecting parts. Now its mated to a bus trans with a Kennedy adaptor. 16" of travel in the ass & 10" on a beam front end. I added about 120' of tubing to the chassis. All new sheet metal from a friend of mine. Its a pretty cool old car. Looks like a 70's open class buggy. The corvair motor is pretty bitchen. The heads were milled off and had elbows welded to them. Somebody had made a custom 6 tube spider looking tunnel ram with an oil bath plenum and a 2bbl holley. I changed the plenum around and made it a 4bbl with a 650hp. Fair amount of head work, good compression, flat tappet cam from Howards cams. Over all a clean little set up. Makes good torq and will get with the program for an old timer... View attachment 128158
Maxi, we used to run a class 5 unlimited 2180 motor
We ran 930 porsche c/v joints to a bus transaxle
no more trouble
Sweet little ride! How the hell do you get in that thing?
