1 - 9 of 9 Posts
Does anyone know roughly what it cost to have a longer driveline made?
Boat Nut
Had Johnray at "BIG A PERFORANCE" build a new one for me last year, and was exact to my spec.
My local guy screwed my last one up, cut it .750 too short for a jet-way, and nailed me $275
I just had one made, and it was $500. I did some checking around, and was quoted anywhere from about $385 on up depending on whether it was the 1310 or 1350 series, length, tube diameter etc.
Recently had a new longer D/L to replace my previous ,made by the folks that build my 1310's , they made the barrel from larger OD heavy wall tubing ,nicely welded balanced ,new Spicer ujoints and spline yoke
just get an old drive shaft the dia you want & measure the length you need & cut off your ends & take it to a drive shaft shop & have them weld it up...easy! :)...just sayin' my .02 cents
FastRat
1 - 9 of 9 Posts
