1 - 2 of 2 Posts
i tore my lil cp tunnel'd bottom mantra's pump down last nite and found a pretty decent bowl , nice work done to it and the pump has been flowed internally, the handhole cover flowed over. the loader is fully v blocked in the center though, is that normal for cp tunnels? the blocker is so long in it , it almost touches the pump shaft. never seen a loader with so much blocker in it:)sphss its a custom built loader that's well built, so i didn't wanna change the boat's current set-up until i run the thing.
in the past , blocked loaders have always hurt me on the holeshot, is it normal to see blocked loaders on cp tunnels?
Depends on HP. When I was racing a daytone in SkiJet II sprints in the 80's I used a V type blocker to help with freeing the boat up and from keeping the pump from being overloaded since I didn't have as much HP to use that much intake. Blockers can work in air intrapment boats just depaends on everything else.
1 - 2 of 2 Posts
