Trick Flow 320 aluminum heads, I like them, flow good, plan is to grind out the crack and weld up them smooth, guessing thin casting, seems to be water on the other side, no signs on water in the cylinder, with an open water system with hardly any pressure and 7lbs of boost may have kept the water out, pulled heads for exhaust valve issue and found this during reassembly, just puzzling and financially scary,
Thanks Impatient family doing great!
