1 - 20 of 23 Posts
The cyl's only fire every 90 degrees...(4 cyls per revolution) 4 cyls, 720 deg = 8 sparks. The dist/rotor (and cam) spins at half crank speed.
Some guy
I noticed the crank trigger only has 4 magnets (least that i can see), how's it know when to fire the other 4 cyliders? The dist has 8 dilio's that fly by the pickup, but from what i can tell the crank trigger wheel only has 4.
Ah grasshopper, does the crankshaft not rotate twice for each rotation of the camshaft(which turns the distributor)???
Boy are you guy's nice, wait til Chet sees that. :)hammers
I guess you have never been 180* out with a distributor ? :)sphss
Sleeper CP :)
Cantard
These guys are messin with ya...... the one with 4 tabs uses dual pickups.
One more question like that Shaun, and you will forced to surrender your timing light and commit the first four pages of Ketterings S.A.E. papers to memory AND drive your boat full speed for ten minutes with the #1 spark lead clipped to your left ear lobe!
Lurker
hil:)hil:)hil:)hil:)hil:)
Cantard
:)Poundhil:) I think this is one of the funniest...
Boat 502
best one on the market ???
Is the MSD crank trigger the best setup out there ? I'm running all high quality MSD stuff and was wondering what other options where out there ? Thanks.
Do you have a 4 cylinder engine? crank Triggerz only work on 4 cylinderz cauze there iz only four magnetz.
Be like shaun and buy the cheapezt thing available then complain when it failz on you, quality iz over rated.
1 - 20 of 23 Posts
