id like to create more vacuum in my engine....does anyone think a vacuum pump from a diesel pickup engine would do the job? i only ask because a racing pump is so expensive?
You may want to check a salvage yard for a "smog" pump. Prior ot Moroso and others manufacturing race vacuum pumps, racers were using "smog" pumps. The first vaccum pump I used on my Competition Eliminator engine back in the early '90's was a smog pump from a Ford pickup.id like to create more vacuum in my engine....does anyone think a vacuum pump from a diesel pickup engine would do the job? i only ask because a racing pump is so expensive?
Does your engine have excessive blow-by? Is it a fresh build ....and why do you want more vacuum? what rpm range do you run it?i have a niebor with a wrecked 88 f250 and the vac pmp was already sitink on the fender so it made me think and it would be free. woud a smog pump be better than a vacuum pump?
on my first build last yr i was getting alot of blowby in the rocker covers. tore that engine apart and am assymbling a different one. i just want to head off the problems before they are problems. I run 3-5k last yr. hope to get more revs this yr. I had read that with the big cam and tunnel ram there are vacuum issues......
Huge difference between manifold vacuum with a T ram, and crank case vacuum. Carbs and manifolds have nothing to do with crankcase vacuum.on my first build last yr i was getting alot of blowby in the rocker covers. tore that engine apart and am assymbling a different one. i just want to head off the problems before they are problems. I run 3-5k last yr. hope to get more revs this yr. I had read that with the big cam and tunnel ram there are vacuum issues......
But you can hook them together with a hose and a metered check valve, right?Huge difference between manifold vacuum with a T ram, and crank case vacuum. Carbs and manifolds have nothing to do with crankcase vacuum.
Lol yep a pcv valve.the electric smog pumps that came on sime f & y body cars works good even s10's had it for awhile and they pull 5-6hg on the inlet side..not sure how long itd take to pull a bbc crankcase into vaccuum at wfo tho, thats alot of volume.i know ls guys use them successfully but ls doesnt have much of a blowby issues.mine has big ring gaps(blown race specs) and i have no need to crankcase evacuation really.never leaks oil or builds much pressure.But you can hook them together with a hose and a metered check valve, right?![]()
