I have a fresh set of Crower 3" Mechanical Stack Fuel injection. This unit is set up for gas. The Nozzles have been replaced with more affordable Enderle nozzles. The nozzles can be changed back to Kinsler style if you want to do that. The Barrel valve is a 54K. The Distribution blockis a Kinsler unit. The manifold is hard coat anodized with polished tops. The tubes are powder coated semi-gloss black and the bells are powder coated candy red with lots of metal flake. I have an enderle front cover and a hilborn 150Apump. This set up was used on my old set of Enderle injection. I have a bunch of new pills, jet holders, and some bypasses. I can help set it up for you if you like as well. I have everything that you will need to bolt this on your motor. I have the shut off valve and cable as well. I bolted the unit on my old Daytona for a photo shoot. Im lookingfor $2800 for everything!!!! obo
I will post up more pictures later. These are all I had in my phone
Thanks
Dave
714-422-7329
Thanks
Dave
714-422-7329
