high flow valve
That's what is really cool about that valve I got from Lowe, as soon as you pull the shutoff it closes and keeps the fuel from draining back and keeps fuel right at the nozzles, you can let it sit over night and it'll start with the touch of the button!..You want to leave fuel in the lines for start up,
What kind of valve is that, does it have an internal check valve or?That's what is really cool about that valve I got from Lowe...
You say Tomato, I say TamaiterThat is just a fuel shut off!..
I got your PM, thanks. I'll be contacting you later today. I got a chance to talk with that 509 guy and look all over his boat. Very cool.I inheritted a set of hoses and some pills for this system if you are looking for any. PM Me if interested. One of the 509 guys runs this stach injection and may be able to help you out a little.
Cy
Hey Ray, think about it the fuel stops when the engine stops, when you kill the mag the engine is still turning over and still pumps fuel until it stops, to shut it off clean you have to pull the fuel shutoff first then kill the mag!..![]()
I shut my engines down like Morg does. I hit the fuel shut off and you will hear the motor lean out (the idle will come up and smooth out) and when that happens I kill the ignition. That way you don't have fuel that sits in your intake runners or cylinders until it starts again, but you still have some fuel in the system.
Paul
Ralph Gorr Fuel SystemsDoes anyone know what the letters on my barrel valve's spool mean?
How much??, what are you looking to trade for???...BTW, anyone interested in a Victor II with an Enderle hat set up for Alky????..Sell/trade????..............Ray
Yes indeed!..PS, Art, you have seen our system first hand, (actually "hands on"), and you would have to agree it starts better than a carb with an electric choke, no prime, no black smoke. Even after sitting for months, just a little "Marvel" smell as it comes to life....KISS, words to live by.........
I can't figure out how to empty the 2 saddle tanks into the T tank without over filling the T tank or emptying the T tank before all the fuel is out of the saddle tanks. I need some sort of float operated fill system/switch operated fill system for the T tank so I can get fuel from the saddle tanks into the T tank without overfilling the T tank... with the photoshop deal I drew out the T tank is going to spew fuel out the vents. The top of the T tank is higher than the saddle tanks and the bottom of the T tank is lower than the saddle tanks.
Here we go again, PLEASE explain this as this does not make one bit of sense!...you will blow the top of the surge tank doing the putabout or towing a skier.
Okay maybe e awrong use of words you may over fill the surge tank and over flow. That depends on how the whole system is plumbed for returns to the main tanks for just a cruise situation. MHere we go again, PLEASE explain this as this does not make one bit of sense!...
Ok two ways of doing it, first you use a street low pressure/volume mechanical pump to fill the tank(both ways)if you use a float bowl deal it works just like a carb needle and seat control the level!.. The other way is an inlet/outlet at the same level going back to the main tank(s)no way they can over fill!.. Myself I don't like the float bowl deal because I had one stick on me once, fortunately it stuck open and I went dead fat, if it went the other way I could have had a melt down. That's when I went to the in/out way and the K.I.S.S. method!!..Okay maybe e awrong use of words you may over fill the surge tank and over flow. That depends on how the whole system is plumbed for returns to the main tanks for just a cruise situation. M
Is the purpose of the surge tank to make sure the MFI's high pressure fuel pump maintain's a constant source of fuel?Ok two ways of doing it, first you use a street low pressure/volume mechanical pump to fill the tank(both ways)if you use a float bowl deal it works just like a carb needle and seat control the level!.. The other way is an inlet/outlet at the same level going back to the main tank(s)no way they can over fill!.. Myself I don't like the float bowl deal because I had one stick on me once, fortunately it stuck open and I went dead fat, if it went the other way I could have had a melt down. That's when I went to the in/out way and the K.I.S.S. method!!..
