1 - 3 of 3 Posts
Can anybody tell me which is the right head gasket for a dart big m block 4.5 bore with afr heads, dart said felpro 1047 and afr said felpro 1017
thanks john
thanks john
The two are basically the same configuration, but the 1047 is considered suitable for marine use because it has a stainless steel core. Both have the 4.54 bore. The 1017-1 and 1047 are .039 thick, the 1017-2 is .051 thick. The 1017 has two coolant holes per end, the 1047 only one. Either will work on your block just fine.
1 - 3 of 3 Posts
