1 - 3 of 3 Posts
I have a 19' Daytona 450#, 685hp that need to be completely rigged. The information I'm looking for is what type of intake to run? I have Berkeley "R" modified to take the standard loaders. I have a low profile "GTH" 4deg. Or the standard 4deg Berkeley.
Also where to set the mouth of the intake, in relation to the transom, Even?
The boat is going to be used to lake race.
Any shared info that has worked for you is appreciated.
Be safe, schick
21 Daytona
what keel does it have? spend some $$ with a good pump person.
like MPD, Jetboat performance, or anyof the other pro's and they will steer you in the right direction.
I agree, ask the pro's
Duane at Hi-Tech performance got my heavy 21' daytona to do 118mph:)devil
Pump work, bottom work, it all helps:)bulb
1 - 3 of 3 Posts
