1 - 2 of 2 Posts
SOLD
This is dirt cheap ! Nearly all of it brand new.
EFI/Ignition Bundle F.A.S.T. XFI 2.0 Fuel and XIM Ignition Systems + Spares
Only requires a download to be the latest 2.05 version.
XFI box was my race spare. New dual injector driver motherboard installed from F.A.S.T. Has datalogging option. Pic details attached.
NEW: XFI main harness, V-8 injector harness, 5 datalog sensor harnesses, Wideband harness, Calport harness.
XIM Ignition 301311 Brand New in Box with harness.
8 Brand New XR-1A coils mounted on a bracket. Bracket attaches to engine block mount holes. MSD superconductor 8.5mm wires with ends for the coils. 2 Factory ls coil harnesses with XR-1A coil connections. 2 60 amp relays if you want to run battery voltage directly to the coils. 1 spare relay.
CO2 boost control valve wired in.
Sensors brand new. Some installed idled but not run: 5 bar MAP, water temp, IAC, TPS, 4 Wide band O2 (2 new in box) several typical fuel and oil PSI one of them 0-500. Spare inductive crank trigger pick up sensors. More also see pics.
Everything Listed Above and In Pics $2,000 SHIPPED or pick up Miami, FL 918 two six nine 8084
Also Available For Sale : Ask for pics
These parts are NEW were installed started and idled.
8 NEW precision Turbo 225 lb/hr low impedence injectors $900
Custom billet HE GM V-8 Cam Sync with slip collar and composite gear $175
NEW Custom heavy wall 304 Stainless turbo Headers SBC NEW a work of art $1800
Belt Drive Enderle 990 with electric prime pump and Magnaflow bypass regulator. $500
NEW 3GPM manual injector system CO2 operated on off valve distribution block hoses and Gorr nozzles. Plumbed into Wilson elbow base. Elbow not included. $200
NEW System 1 EFI fuel filter and mount. $180
NEW Procharger Red Race BOV $350
NEW 16 Volt Racing Battery and Alternator $400
Discussion Starter #2
Bump priced Dirt Cheap
1 - 2 of 2 Posts
