Because to little duration and too much static compression can create too much Dynamic compression depending on the application, or vise versa, too little static compression and too much duration will let all the compression out and make a pig. i'm sure thats just the tipcamshaft selection? Why is this asked when selecting a camshaft for a performance application?
On the seventh day it rests....................now I know I'm wrongThe camshafts "work week" is during 2 cycles. . .the intake cycle and the exhaust cycle. What does it do during the compression cycle?
Just re-read this, Is this a trick question? If the question is pointed at a given cylinder i'd say its resting, but on and engine with multiple cylinders the camshaft as a whole should always be moving something, no?The camshafts "work week" is during 2 cycles. . .the intake cycle and the exhaust cycle. What does it do during the compression cycle?
Bob, Let's not get into Ram effect just yet. Let's keep this simple. I promised Mike F I would go into Ram effect and we have this as another "winter discussion".If you did your job rightat the bottom while the piston is in a dwell state and part way back up, slowly gaining momentum, it is still in an intake mode (in a given RPM range). Below that range, some of the intake charge get pushed back up the intake track. The further below the range, the more so, there by lowering the effective compression of the motor. If I win, please send my free roller to 288/298 @ .050 Drive, BBCalif.
When it comes to camshaft selection, I spend a lot less time considering compression ratio than I do other far more important factors such as the in/exh port designs and their performance, engine displacement, intended rpm range, other engine combination factors, etc. I don't feel compression is as big a factor as many seem to think, when it comes to planning a camshaft. Power making, YES compression plays a big role, but compression's influence on cam profile is not to me as significant as others seem to take it.Why is this asked when selecting a camshaft for a performance application?
i don't know , but it's sure beats call me and i'll sell you a cam when someone asks a cam tech question . i agree with lakes to a point and then with Josh that too much duration without increasing port flow and compression will kill the cylinder pressure and not increase power or extend the powerband .Is this a quiz or something?![]()
Thank You. You said that so well.When it comes to camshaft selection, I spend a lot less time considering compression ratio than I do other far more important factors such as the in/exh port designs and their performance, engine displacement, intended rpm range, other engine combination factors, etc. I don't feel compression is as big a factor as many seem to think, when it comes to planning a camshaft. Power making, YES compression plays a big role, but compression's influence on cam profile is not to me as significant as others seem to take it.
And that's all I'm saying about that...
LO
P.s.: Hi Chris, been slammed, hope all's well.![]()
X2i don't know , but it's sure beats call me and i'll sell you a cam when someone asks a cam tech question .
When a cam company ask you how much compression in the engine why do they need to know? The cam deals with 2 cycles and neither is the compression cycle, so why do they need to know this?
