I'm running a front mounted distributor from my jesel belt drive so I need to use a distributor button to drive the oil pump. My question is how do you line up the oil pump drive with no rotor to rotate the shaft as you drop it in? I was told that you could just rotate the crank until it lines up, but that sounds like a good way to damage the gear.
