.20 crush ? isn't clearence suppose to be aroud .005 i forget ?Are those plastic shims good for shimming the distributor housing?
without a gasket my distributor has a .030 gap between housing and manifold, my gasket is .050 thick new.
I havent checked gear mesh yet.
msd shows 10-30, but I know those gaskets crush over time. not sure how much.20 crush ? isn't clearence suppose to be aroud .005 i forget ?
IMO...if the dizzy doesnt sit flat on the manif without the gasket, u have a prob elsewhere!...check the gear mesh...check the pump rod length...it should sit flatwithout a gasket my distributor has a .030 gap between housing and manifold, my gasket is .050 thick new.
Don't forget that your depending on the intake manifold manufacturer to machine that area perfect, which would only be good till someone machines the head or block or uses different thickness head or intake gaskets.IMO...if the dizzy doesnt sit flat on the manif without the gasket, u have a prob elsewhere!...check the gear mesh...check the pump rod length...it should sit flat...just my .02 cents
FastRat
Hey Paulmsd shows 10-30, but I know those gaskets crush over time. not sure how much
I've checked the clearance on the shaft/ gear when I replaced the gear.Those shims are much smaller than the gasket to seal it to the manifold. Distributor shims are to keep the inner shaft from bouncing up and down causing wear and spark scatter. Extra gaskets on the intake manifold will keep you from loading the oil pump shaft and sending steel into the oil galleys.
Needless to say both clearances need to be checked!
