I have some angled cut 3 inch exhaust tips that don't have any flappers do they sell them to install internally.
He hydro locked his motor. Couple of members suggested he might need flappers. Either that or he over pressured the block and pushed out a gasket.With your type of exhaust, you might not need them. Water has to travel a bit high to get over your riser. I have regular snails and both my flappers only have one side left and ran it that way all last season without water issue. I park my boat with current or nose out when I can.
I doubt water traveled up and over his risers. I have snails and they are much lower to water level with only half my butterfly left. No water issues yet...I think his issue was poor gasket coverage at the riser or manifold intake gasket.He hydro locked his motor. Couple of members suggested he might need flappers. Either that or he over pressured the block and pushed out a gasket.
Yes. The pressure will rise as RPM increases.Is it the faster you go to more pressure it gives mabe it was open to far like before I was only getting 35 and now 48 mabe that extra pressure it wasn't used to blew gaskets. I think it was set at half open
