1 - 4 of 4 Posts
77 sleek.
I’m needing to replace a starter on my 460 top mount ccw berkeley bellhousing. There are a few on there site but want to know which one to get. I bought a pmgr from them but it wouldn’t work right so I returned it
...460 top mount ccw berkeley bellhousing. ...
I think the difficulty here is that the top mount uses a different starter than the regular 460 would use.
Arco has some good tech information on their site that applies regardless whether you buy their product or someone else's. Likely you would need something like the ARCO Marine 30456 or 30457 for the top mount bell housing (depending on the rotation direction of your engine). Their tech tips show you ways to figure out the proper rotation. Check out these links to see if you can answer your own questions.
htARCO Marine Tech tips
ARCO Marine Starters
77 sleek.
Ford 460 berkeley pack a jet starter
What starters are you guys using on you berkeley bellhousing top mount. I’ve seen top mount starters on cpperformance and Hardin marine but don’t wanna spend $269
1 - 4 of 4 Posts
