H2OMOFO, Its seems painfully appearent that the PRs are to short. There is no pic you have posted yet where the roller center isn't above the center of the trunnion.
I don't need a little T square to see that the roller center is well above the trunnion center in this pic:
Those 2 lines you drew should be at 90*. Maybe they are in person, but they sure as hell aren't in this pic. And seriously, I doubt they are. Let me try it this way. That line going through the trunnion and roller centers, it needs to be PARALELL with the top of the retainer. PARALELL, no even with or flush with, just dead inline with. Your lift is probably of because, either you didn't subtract the las for the stated lift. All cams are listed as gross lift without the lash subtrsacted. Also, the wrong length PR will result in less lift. Specially too short.
Is it this pic, or has that valve tip been hammered through all this? It so, get it fixed. It will just tear up you valve guide. Not counting the fact that if its a rounded as it looks, really tough to keep a rocker on.
You can get longer adj. PRs alot of places. Jegs has them.
LINK: 9"-10.170" adj PR
Your not going to find the correct PR in some catalog. Summit sells virtually every imaginable length on line, and you can order custom lengths from Manton, Smith Bros. and Trend. This just the lengths Summit sells in Scorpion alone. Once you open the link, just click on the "show all" for both intake and exhaust.
LINK: Scorpion PR list
I know this all seems like a pain in the ass, and it is. But would you run your lash at twice recommended? Or run a .080 spark gap? Run your timing at 12* total? While this may not seem as important, it can be. Right is right, and wrong is wrong.
