1 - 15 of 15 Posts
what are you guys running for push rod sizes.. 3/8, 7/16,5/8 you hear alot about cam size, but not alot about the push rods themselfs. I've got a mild build 461 bbc,with roller rockers and solid flat tappet a 640 lift
Oh yeah it does just ask _ _ _ _!!! hahahahahaha I can tell you where to buy a set of $400.00 ones??? I think you know what I`m talking about... Pete I think for either of us we just need to go to MANTON in Lake Elsinore and let them tell us what to run.
IMO pushrods can't be "too big". There is far more strength in cross sectional area than there is in wall thickness, ie: I;d rather run a thinner wall 7/16 than a heavy wall 3/8. In your case, depending on rpm, a quality 3/8 x .083 wall should be plenty. I spec a minimum 7/16 pushrod for any solid roller engine I build now.
just trying to get some info from the big dogs..because i'm sure they have been there and done that..:thumb:
Pete - You can have the 3/8 x .083 ones that we changed out at the Elsinore race... I dont need a full set (that arent ment for my motor) for spares!!! I have 2 int & 2 exh extra I just found.. that should be all we need to run the magic number this next season... This sunday you ready to put the work shop back together? Then we need to tear that pig apart....
thanks i'll cheak them out but i think there going to be a little off. Since your set up is for a roller. mine measures out at 8.550 intake and 9.500 exhaust ..but lets get that thing dialed in, we got some racing to do
DITTO. It does not take a 7/16 push rod. more along the lines of geometry. I personally run the lightest push rod I can and make sure it is not getting so far out of angle that it will become a pretzel. I will also admit I am not a big lift cam fan! I spring the head/valve combo to be able to handle the intended rpm of the engine. Cstraub would probably be the best to give the best advice. MLAO Mark
Remember that is why I needed the special 400.00 dollar ones since it was for a roller and those were from the old motor before roller...seat pressure crap I guess... I`m about done with that cam though it better wake up with the stuff we`re doing this year!
you can get away with almost anything with that 5/8 pushrod what the hell is that ???? lets go for a .840 and do away with the lifter
Never use them and I don,t have a problem
Weight on the lifter side of the rocker is far less important than rigidity, and how do you change the pushrod angle other than off-set rockers and lifters? Are you saying you go to that extent? Shaft rockers and light pushrods? How do you know how much spring pressure you need?
I feel this is more dictated by spring pressure and engine rpm and even cam profiles/dynamics. OR call manton.
Cam profiles and rpm...yes; spring pressure, no. Spring pressure does two things...it keeps the lifter on the nose of the cam, and keeps the valve from bouncing when it closes. In a lot of cases, engines are running way more open pressure than necessary to help control lofting, which is caused by pushrod flex. We already have a valve spring, we don't need the pushrod acting as another one. With bigger pushrods and getting the lofting under control, you may actually need less open spring pressure to control the lifter.
Dead on! Pushrod weight is waaaaaay over blown. Although angle is a factor, the angle is what it is, and you can't change it without offset lifters, or rockers or both.
Pushrod stiffness is huge. If you think the big boys are raising the cams in their blocks, guess again. They don't have a clearance issue with a 3.62 stroke.
When it comes to PRs, short and fat rules.
1 - 15 of 15 Posts
