1 - 5 of 5 Posts
Ok I called dooley to find out what size the plugs are so I could order the correct oil temp sender unit for my new oil temp gage. They told me 1/2 inch so I ordered one but it sure looks big to me. Does this sound correct? I have a 14 qt Dooley jet pan.
Not sure what the thread size is in a Dooley pan, but if its 1/2", then thats 1/2" SAE fine cap screw. Stock GM oil pans are 12" X 20. Your sender is probably 1/2" pipe. 1/2" pipe is much bigger than a 1/2" cap screw.
I'm sure you are correct I just ordered a 1/8 inch sender then I will used adaptor to get it correct
Well finally got a look at my oil pan today and there are 2 plugs in the pan one at rear that is a normal drain plug and one at the front that is a 1/2 inch pipe plug.I'll be damn
1 - 5 of 5 Posts
