1 - 19 of 19 Posts
I know this is a loaded question and will get a million different answers (kinda like aluminum impeller hp level).
At what hp level does it become necessary or a good idea to double drill the bowl to the intake housing and the snoot to the bowl?
this is on an early dominator 12-S
I'm around 900 in my lake boat and nothing is double drilled and no issues blowing gaskets .. In the race boat, the bowl is double drilled but the droop is not .. Still no issues !!!!! I'd go with a 1000+
Urban Cougar Trapper
I had mine done while pump was out , seemed like a No Brainer ...plus I've seen the plastic wedges get blown out even in some boats with moderate power ...will it actually help in my setup ? Who knows but I sleep better
lost bowl
I blew the bowl off onetime. Pretty dangerous as it was swinging around by the cables at high speed. Could have been because I was running hard across some rollers and stayed on the nos.
What the Hell is That?
For the guys who double drilled and studied or even those with regular bolts, why not have them safety wired also? Seems to be full proof at that point.
Most of the time if your blowing gaskets and bowls and droops off, you either don't check your shit, bolts are to short, or some major loading issues :wink2:
Fuck it, drill it :)devil
Never had either end of my bowl double drilled on the 828 and never blew a gasket. Upgrading to the new suction housing & larger diameter bowl this winter so going to go ahead & have it double drilled, not sure if its necessary though.
I just studded mine with SS Studs and Nuts , Nuts have the Polylock Insert ...if they are backing out ? I've got something worse than that going on ! :)sphss
When it happen to me, 4 of the 8 "regular" bolts pulled the threads right out of the bowl. At that point, all the safety wire would do is keep the bolts all together as they sink to the bottom of the lake...Don't get me wrong, safety wire has its place but, not sure about it in that area. Double drill, stud it, nuts, lock washers or nylocks and don't look back.
1 - 19 of 19 Posts
