O.K. I need some more opinions. My 74 sanger came with what I guess is what was used before whirlaways where invented. It is a drive shaft coupler that releases in case of engine seizing. mine is damaged, and I was thinking of using it temperarily,as I have to many other parts to buy before I can afford a whirlaway setup.I am posting some pics of it and the damage it has. Basically, I want to use a stainless steel split clamp perchased from a truck supply store to clamp around the area that has its bolt ears broken off.the clamp is about 1/2 inch wide and is 1/2 inch thick stainless steel.The coupler has its keyway undamaged, and the set screws keep the shaft from slipping out.Is this a reasonable temp. fix, or am I looking for trouble?Would it be better to put in a solid coupler for now? I'm pretty sure the mild engine I am starting out with-400 hp or less-isn't going to eat itself up and seize.Any thoughts?
Please.... Absolutely do not run that part in that condition. I ran an Algon and am familiar with them. You are asking for an explosion of parts that could injure or kill someone trying to fix that with a clamp.
You might want to give Sanger a call (Stellings) they originally made them and may have parts laying around to fix.
Brendella 2" Runner NoS
Perf Boats avoids another disaster
Holy crap, yes. Listen to this man and the others, that sh*t patch job *will let go* and cut your balls off. Y'know, bad things happen even when the top-of-the-line stuff sometimes fails - Buy the Whirl-a-way II from Casale or guys on the site. It's the 2nd most important safety part you can own.
