Retired Air Force
I want to use stainless steel studs to connect the bowl to the snoot to prevent corrosion. Steel studs rate at 125,000 psi tensil while the stainless steel rate at 75,000 psi. Are they strong enough? I have 850hp
Amerian Turbine Man
Bowl studs
If its double bolted stainless steel should be good.
Ron
"Member"
ARP makes real nice s/s stud's they've worked real well for me. And that much HP double drilling is a good idea. just my .02
