Status
Not open for further replies.
1 - 3 of 3 Posts
Auto verdi six stage dry sump, Dan Olson kick out pan for a BBC. It has the DRCE bolt pattern (bolts line up with main caps). 4 section pan.
Includes pump, dry sump pan, pulley, belts. 5 -12 scavenge lines to the dry sump pump. 4 from the pan and 1 from the valley. 2 -16 return lines from the pump to the tank. 1 - 16 supply from the tank to the pump. 1 - 12 from the pump to the oil filter pad. All the lines are aeroquip startlite hose, earls fittings. the scavenge lines and return lines have the aeroquip inner coil. I spent just under $1200 just on plumbing this setup.
You will need a tank, oil filter assembly and a mandrel. This is set up for a BBC mounted on the drivers side. I'll include a motor plate that fits mounts the drysump to the block.
SOLD
Located in san diego.
1 - 3 of 3 Posts
Status
