ive sifted through alot of threads and probably havent found the right ones or all the ones i need to read. so if you know a good thread i need to read let me know. anything to do with pump parts and impeller/motor set ups/combos with reasoning behind what the parts accomplish and how, i will read.
little info - my friend is an engineer and im an over paid welder we are both smart in diff areas and, both grew up working on stuff ourselves because we have the know how to figure it out and like to save money. we like to butt heads with each other on ideas until we figure it out the same. kinda like math, prove each other right or wrong. me i grew up around jet boats and until this year my knowledge was "blue print and balance it all, get a jet-o-vator for trim adjustment and haul a$$" i been around alot of diff boats that had diff droop snoots and diff pumps and big motors in expensive pickle forks with expensive pumps that got there a$$'s handed to them by stock motors and stock pumps. 26 years of this i bought a bought a boat that had a wedge on the pump and i was dumb struck, never seen or herd of a wedge. kind of still dont understand the purpose other than a cheaper way to get more speed with out the adjustment of a jetovator.
"our arguement"
we are talking about the same boat pump and impeller of any make you choose.
we both understand in our own way limitations and torque curves of impellers.
our arguement started off as making a small block motor work with the same impeller made for a big block set up
we both agree that if you build the motors to match the same torque/hp (power) range that it will work fine
were we dont agree is here. he says the if that impeller was made for say 550lbs of power at 5500rpm he dont see why you cant get more thrust out of another motor, wether it be big or small block, with the power range surpassing 5500 carrying the power band another grand or two and put out more thrust on that same impeller being as the charts are a ruff guide.
in my understanding of the impellers, the power range of the motor has to match the power range of the impeller. so if i have a boat with a bb and an impeller matched to its dyno at peak power of 5500. he says that his bb or sb race motor that can carry the torque/hp (power range) another 2 grand more will put more thrust on the same impeller. to my understanding the motor should work fine but i think you need a different cut to get all the thrust you can with the motor spinning that extra 2000 rpms more or your just wasting energy.
also we are bumping heads on changing the bowl and nozzle setup to compensate for that extra 2grand. he thinks you can and i think your just changing the use of the max thrust that impeller is giving you.
we agree and disagree but can prove each other wrong or right.
are we both wrong or are we both right? i dont want no bashing each other it distracts my train of thought. just facts, theories, and personal experience on how it works. prove us both wrong prove us both right. there is no stupid question just uninformed people. and like i said if this has already been argued and settled on another thread i havent found it yet.
"our arguement"
