Just because I am curious...what is the better way to do EFI...draw thru or blow thru?
Draw through is old school.
Prone to fuel settling out in the compressor and piping.
Add an intercooler and the problem is compounded.
I did it that way back in the 80's when I was racing sand drags.
Maybe the rocket scientist here can explain to this dummie how a turbo needs to be something special to deal with draw thru as opposed to blow thru, or how fuel puddles in the cooler, or manifold if the EFI throttle body is before the turbo. Or why you need special computer skills that different for a draw thru than a blow thruDraw through may be old school, but it has been working for many years and generally, it's way cheaper.
There are a couple of limitations to draw through to keep in mind. Generally you may be limited to the cubic inches
that it really works with and not all turbos are comparable with the draw through system.
On the other hand, if money is not an object, blow through is usually better if you know how to operate a computer.
I'm sure others will chime in with more details, both for and against.
Yea, draw through is old school, but we know it works...![]()
As opposed to a roots sucking thru a hat???I DKS about turbos, but I would think the blow thru deal would offer better perf. having positive airflow available at the intake above the tb, as opposed to having the tubo sucking the air through it then sending it down stream to the intake. Like I said I don't know squat, just my thoughts on the way it would work.
No plumbing for the roots air to get to the intake, its all right there close together, and no science to back the thought up, just a thought thinking about available air. Kinda like why the car man. have all added big plenums to the engines of modern cars.As opposed to a roots sucking thru a hat???
No doubt a blow thru throttle body can be made less complex, simpler and lighter. Plus you can even use fancy dancy inlet bells with trick little inlet guide vane on them. I see no benefits to a draw thruNo plumbing for the roots air to get to the intake, its all right there close together, and no science to back the thought up, just a thought thinking about available air. Kinda like why the car man. have all added big plenums to the engines of modern cars.
As far as the puddling thing, I thought you were joking. Kinda hard to puddle fuel in the inlet hoses when its being injected in the manifold!No doubt a blow thru throttle body can be made less complex, simpler and lighter. Plus you can even use fancy dancy inlet bells with trick little inlet guide vane on them. I see no benefits to a draw thru
My original question was how a draw thru efi creates fuel puddling or require different computer skill set.
No I wasn't joking. The forum EFI guru was the one that posted that draw thru can suffer fuel puddling.As far as the puddling thing, I thought you were joking. Kinda hard to puddle fuel in the inlet hoses when its being injected in the manifold!
I would think you would loose alittle throttle response and add alittle lag, not to mention you could get an adjustable bov that could also serve as a max boost controlI think he missed the part about it being EFI at first.
Wouldn't draw thru efi be better though since you can eliminate the BOV and limit air going in rather than blocking air going out?
Maybe the rocket scientist here can explain to this dummie how a turbo needs to be something special to deal with draw thru as opposed to blow thru, or how fuel puddles in the cooler, or manifold if the EFI throttle body is before the turbo. .
I am aware of the seal issue. I am still hung up on the fuel falling out of suspension due to the throttle body being ahead of the turbo. and intercooler. In fact there has been a couple pics of throttle bodies before the cooler on a couple boat engine in this thread. Do they have fuel puddling issues in the cooler as well?I know your smarter than this Bob but since you asked.
If the carb or throttle body is ahead of the turbo it pulls manifold vacuum on the compressor housing.
The turbo then needs a carbon seal to on the compressor side or the vacuum will pull oil out of the bearing housing.
Along with this fuel in suspension will settle out in the long path between the carb and the head.
This happens more in cooler weather but the system is prone to this and I've had it happen many times.
It's just old school and undesirable. Kind of like you Bob
