1 - 2 of 2 Posts
From the battery (the distance to the terminal block is 18) feet that's where all the connections will be made I'm thinking of running 10 gauge wire is that to small or go with 8 gauge, it will power 3 bilge pumps only used when needed a IGN,Tack,Temp and volt Gauge MSD box will be direct to the battery, Will 10 Gauge be sufficient for that distance, Thanks
1 - 2 of 2 Posts
