Whats pro's con's about the fuels? Thinking about going Alcohol :yes:!!!!
will be a birdcatcher with a weiand t-ram. Bracket boat. 474 c.u BB chevy gen 5 steel gm crank, eagle H beam rods 13.5 cp pistons, 680 solid roller jet boat cam, comp roller rockers K.E. 320 aluminum offshore heads. gear drive, zig mag. have zoomies and bassett hedders. The hull is 900 pounds as you see it with goodies attatched.Set it up right with alcohol and you will love it, 1 ?, is it blown?
I would definitely run alky!swtd:1473761 said:will be a birdcatcher with a weiand t-ram. Bracket boat. 474 c.u BB chevy gen 5 steel gm crank, eagle H beam rods 13.5 cp pistons, 680 solid roller jet boat cam, comp roller rockers K.E. 320 aluminum offshore heads. gear drive, zig mag. have zoomies and bassett hedders. The hull is 900 pounds as you see it with goodies attatched.Set it up right with alcohol and you will love it, 1 ?, is it blown?
Call ask for jim at Enderle and also Good vibrations in Whittier. They know all about these setups. Great help:yes:With alky you will have to use a fire suit if racing?
I like the tunnel ram injection idea and want to run it on my boat also but looking on the net it is kinda hard to find info on..
TIGEDLR.. Your boat looked like it was movin last weekend)THumbsUp and looks great!
We have it running 110 MPH on GPS.How does your combo run?
Chris, are you going to take it to the races? I'd like to watch it run. If so, when?We have it running 110 MPH on GPS.
Steve, we may go in Sept. and let my son drive.Chris, are you going to take it to the races? I'd like to watch it run. If so, when?
Will see what my combo will do soon gps versus the lights:shock:We have it running 110 MPH on GPS.
