1 - 5 of 5 Posts
496 HO, X drive. Can you use a utility bucket (large enough to hold the whole unit) vs. ear muffs to run your engine?
It's what we do
Yes
Don't do anything but idle it, at any rpm it will suck the bucket dry instantanously. My 25 with the B-Max will suck a 20 gal. utility box from Home Depot dry in 12-15 seconds with the garden hose running wide open into it. A Bravo has a bigger pump than an Alpha, it also depends on the pump ratio, they're not all the same. TIMINATOR
I personally think the ear muffs are a lot easier to work with and I've ran plenty of motors with them without and problems but that's just me
New here
I have always used muffs and duct tape, for one reason. When I am doing this, the boat has usually been sitting for a significant period of time. Therefore, it is quite conceivable that the impeller in the sea pump is bone-dry. So, using the hose and muffs PUSHES the water up to the pump. I just turn it on 1/4-1/3 if I am alone / start the boat / and then walk back to turn up the water over 1/2.
On shut-down, I turn the water almost off, just a trickle. Then shut the boat off. I have pretty high water pressure at the house, so I don't like to over-do it.
1 - 5 of 5 Posts
