Was there water in the bilge? Sometimes the flywheel will make it look like water is coming out oth the front of the starter when the motors running.
Cut the oil filter open and see whats in there it will tell you if your wiping out bearings. Loose valve adjustment will cause low oil pressure.
Just throwin stuff out there. Good Luck.
