??Wet exhaust cam question??
Will this Erson cam work without having water reversion problems? Going in a 452ci bbc(427 +0.125 bore), 13:1, 049 heads, E85, edelbrock victor jr intake, Glenwood logs, Harman snails
Cam specs:
.770 lift intake and .720 exhaust with a stock 1.7 ratio rocker arm.Duration is 322.Lobe center is 112.the intake centerline is 108 and the exhaust centerline is 116.
Cam specs:
