1 - 14 of 14 Posts
what kind of bowl and impeller is that? looks like bronze of some sort. They handle that kind of HP you have instead of SS? just wondering. be safe.:))THumbsUp
149 BGJ-Willis Power 540
Discussion Starter · #6 ·
this may be a dumb question, but, why is your hand hole cover so tall?
$uperJoe,
Jet tech 101. :grin:
In race applications, there has to be a device to ensure that the boat can slowdown without “Stuffing the Bow”.
What you think is a hand hole cover is the device that allows water to escape from the jet drive for that purpose, “Pop-off Valve” is what it’s called.
Willis
Discussion Starter · #7 ·
Spiritof76Cobra
That jet drive bowl was designed by Dave Jones, “Pops @ Aggressor”, because we wanted thicker material at the beginning of the pressurized water flow transition from the impeller to 9 vanes Aggressor Bowl where it begins to necks down.
Since then, late 2006-07 until Dave Jones stopped making the Aggressor parts, they all were machined that way to be thicker. :grin:
The impeller is an Aggressor manufactured before 2010 and it will be fine as far as being safe.
Several Blown Gas Jet Record holders have used these part and had great success. :secret:
Willis
Awesome. What are your guesses for ET and MPH?
Discussion Starter · #9 ·
Unknown, but better than 7.80, MPH more than 125 less than 145 :)Unsure
We are not looking to set the track on fire. Just get the bugs out and make decent hp & ET.
Willis
Discussion Starter · #11 · (Edited)
Extreme Jet Drive - Cyclone Speed & Marine
May 21, 2012
Hello People,
Mike Miller,
Thank for the intro to Bob, from Vortech
John @ C&J Engineering - Good to see you and the news was welcome.
My lake boat Carbs are still hanging in there,
your work in spot on every time I change configuration. :shock:
Cyclone Speed & Marine – Jim Brock,
the jet hooked up like you said it would and the rpms are in the ball park.
Ron, Thanks for all those suggestions and tips.
We had minor damage to the power plant and it will be back together for the Elsinore race. :)eh:)
Willis
Amerian Turbine Man
Spiritof76Cobra
Willis[/QUO
Judging from the photo I'm seeing it's a Berkeley bowl.
Ron
Discussion Starter · #14 ·
Spiritof76Cobra
Willis[/QUO
Ron
Ron,
Yes the first setup was and the one that split was a Berkley.
Most of all the bowls manufactured today have thicker transitions in that area.
The current impeller is a Triple A Aggressor Bronze and we think it will do just fine after I fix this oiling problem.:)Unsure
Willis
1 - 14 of 14 Posts
