1 - 20 of 30 Posts
HEY GUYS I POSTED A THREAD A COUPLE OF WEEKS AGO ABOUT MY 460 MAKIN NOISE ONLY WHEN UNDER A LOAD I PULLED THE MANIFOLD OFF AND FOUND THE INTAKE PORTS COVERED IN A STICKY VARNISH LOOKING LIKE BAD GAS BUT IM CONCERNED WITH THE FUEL TANKS THEY ARE FIBERGLASS AND THE BOAT IS A 76....JUST WONDERING THE EASIEST WAY TO CLEAN THIS UP WITHOUT PULLING THE WHOLE MOTOR APART AND IF ANYTHING TO TRY AND CLEAN UP THE INSIDE OF THE TANKS ANY HELP WOULD BE APPRCIEATED.......THANX:)devil
time to cut out those tanks and replace em, the ethanol in gas has eaten them up:)bulb there's no repair, its a replace kinda deal;) start looking for some alum saddle tanks.
79 Sanger Picklefork
X2..if you don't replace them you will just be fighting the situation for ever. It's only going to get worse over time..
Razor Wire Militia
I highly doubt its the tanks going away.. i would bet its old dead fuel that has built up a film on the inside of the tanks.. just a FYI for the ones that don't know 99% of all fuel tanks used at gas stations are and have been fiberglass for many years. in Commyfornia they have C.A.R.B. (one of the most controled states) that sets the standards for all stations and I highly doubt they would let you put a tank in the ground that eats its self away after yeas of service.. just my .02
every fiberglass storage tank in my area has leaked and had to be replaced within the past 2yrs;) not making that shit up(i end up being the 1 to repair em), they'll leak out the fuel, then water creeps back in. wasn't 3wks ago i was at 1 of the stations fillin up my lil blazer with unleaded, went in and paid, started my blazer up, lit a cig, and made it 2blocks before it picked up the water. they took care of it(my bill), but they had to replace both of their unleaded tanks due to ethanol damage. the manager of that store is a friend of my wife's, she said the storage tank company told her they were overloaded with unleaded tanks that needed to be replaced asap due to leakage related to ethanol.
could be you cali folks get a different unleaded formulation than we do, the shiat is no joke here.
AIR POWER
I just replaced my fiberglass gas tank due to ethanol in the gas that ate up the tank. If you google it you will see that there is alot, alot, of people that own boats have sued the oil companies due to gas leaking in the water from their tanks from the ethanol eating em up.:)st
Well known problem on boats.
Boat Nut
Every gas station in IL. has had their tanks yanked out, and replaced since using ethanol since the early 90's, most all are soil contaminated too. My buddy bought a low time jet boat, had sat for 20 years. upon using the boat the second time the tank started to fail. Glass tanks have had their day, but in todays world of green that day is gone. Glass tanks are however, still being used in aircraft, oem and retrofit, but there is no chance in hell of getting an "auto fuel S.T.C." in these aircraft.
We've had/seen and replaced several of these glass tanks over the recent past , seems like more Spectras than anything , have never done a fuel analisys but I've heard and read that the modern fuels attack the fiberglass, the biggest issue Ive seen is flex and crack . (Not that this doesn't take place in metal tanks as well) my feeling is if theres a doubt its not worth a disaster The bottom picture as I understand could possible been from a fuel leak Tom
NW Spectraholic
Funny you mention Spectras Tom. I actually took my tank apart to fix a loose baffle. While inside I didn't really see any evidence of gas eating into it, but that's just one tank I guess.
you can buy an additive that neutralizes whatever it is in the fuel that attacks fiberglass. i know alot of 2 stroke outboard folks run it now to keep from damaging rod bearings(2 strokes have roller rod bearings). i seen it on the quicksilver mercury sight awhile back. here in my town, the stores are compete'n and some of them have big signs out frt. " 100% gasoline/no ethanol" so i've been getting my boat fuel there.
Does anyone know whether a polyeth tank will survive the newer gas formulations?
should, most race fuel jugs are polyeth aren't they? i know 90% of the lil red outboard fuel tanks are polyeth and they seem to hold up well.
I build gas stations and in the past 9 years of doing so, none of my stations have undergone any tank replacement single or dual walled tanks and all ave been fiberflass. The lines for fuel delivery and vapor recovery is also fiberglass. I would doubt that the fuel would eat up these tanks and somehow I doubt that modern fiberglass is better than pre air recource board regulations.
Discussion Starter #16
thanx for the response on the fuel tanks any way i can clean the motor up without breakin the whole thang down the builder said he has to rebuild the heads because all that varnish stuff is in the valve guides and evrything else....just wonderin if theres a way i can clean it all up my self the motor only has about an hour of run time so i hope its not in the cylinders.....
I went through this on my Spectra 24XS. Ethanol ate the tanks away and filled the motor with badness. The only solution was a rebuild of the motor and replacment of the tanks. IMCO built me two new 33.3 gallon tanks for just under $1000 bucks out the door.
Aloha
AKA OhOneWS6
More fuel for the fire so to speak. This article speaks of the black reside the OP talked about.
http://www.boatus.com/seaworthy/fueltest.asp
On an unrelated note, I had to take my 2007 Lexus in for a recall on the fuel lines not long ago. It seems the ethanol is eating away the lines. I have two friends that are long time Lexus mechanics. One at each of the Dallas dealers. They have both seem first hand lines with pin holes in them for the erosion caused by ethanol. According to my one mechanic fried fuel pump failures were also on the rise with the addition of ethanol as an additive.
As for the post about the "competition" between gas stations, It has to do with emission and non-emission counties, It is not up to the station if they have ethanol as an additive or not.
I am in the process of replacing my fiberglass tanks after the boat ran very poorly. What I found inside the two predators' fuel bowls was about an inch of congealed resin, I believe. Can't think of anything else it would be. It turned solid (grainy) when it dried and it made it past two functioning fuel filters. I disassembled them to make sure. I'm not trying to jump on the bandwagon blindly, but the tanks were cracking and leaking also. It could be sediment/varnish, but I have seen that and this looked nothing like what I have seen in the past.
so who is everyone using to make custom tanks for replacement?
I would like to keep 30+gallons on each side.
What is best? Stainless? Alum? plastic?
any problems with above deck regulations?
1 - 20 of 30 Posts
